NetDrive version: 3.8.915
Windows/Mac Version: Win10 Pro x64
Dear all,
why is a via Netdrive3 mapped Google Drive very slow compared to other software?
Below are two pictures, where I noted the used software. It’s the same file, same machine, same Internet connection.
A normal client :
1. upload or download command
2. the client transfer the file to the server.
NetDrive :
1. shell(explorer or finder) copy command.
2. The shell writes part of the file to the buffer.
3. NetDrive transfer the buffer written by the shell.
4. Repeat steps 2 and 3 until the shell writes to the buffer for the entire file.
As you know, because NetDrive is a filesystem, NetDrive cannot transfer files by itself.
OK, understood.
I did consider that Germany is a development country with regards to the internet, but the factor 22 of the a.m. example seems a little bit too high even for a development country.
