This topic lists the known issues for NetDrive 3.7.
- Dropbox - You cannot modify Microsoft Office files directly from mounted drive.
- Mac - Incorrect file creation and modification time (frequently on Google Drive).
- Mac - Cannot successfully uncompress zip files on mounted drives. Files are uncompressed into a temp folder whose name starts with a dot. If you turned on an option to hide dot files and folders you cannot access the uncompressed files.
