nd3cmd : Command Line Interface of NetDrive3
nd3cmd <cmmand> [<args>]
List of commands
- login : Login with bdrive account.
- logout : Logout from NetDrive.
- whoami : Show email address of a user kept logged in
- drivelist : Show drive list.
- connect : Connect a drive
- disconnect : Disconnect a drive
- refreshpath : Refresh a folder list.
login
nd3cmd login [-f] [-k] [-u useraccount] [-p password]
Login with bdrive account. If you are using SNS login with Google, Twitter of Faceook, then visit Bdrive and set password.
options
-f : login after force logout another user
-k : keep me logged in
ex)
nd3cmd login -k -u email@host.com -p password
nd3cmd login -u email@host.com
nd3cmd login
logout
nd3cmd logout [-f] [-u useraccount] [-p password]
Logout from NetDrive. If there is a user kept logged in, the user will be logged out.
-f : force disconnect even though there are uploading files.
whoami
nd3cmd whoami
Show email address of a user kept logged in.
If there is no kept user logged in, show nothing.
drivelist
nd3cmd drivelist [-u useraccount] [-p password]
Show drive list of a user.
connect
nd3cmd connect -n “drive name” [-u useraccount] [-p password]
nd3cmd connect -i id [-u useraccount] [-p password]
Connect a drive. “id” is a drive item’s id. The id can be got by a command “drivelist”.
-n : Connect a drive by drive name.
-i : Connect a drive by id
ex)
nd3cmd connect -n WebDAV -u email@host.com -p password
nd3cmd connect -i 1432
disconnect
nd3cmd disconnect [-f] -d letter/path
nd3cmd disconenct [-f] -i id
nd3cmd discoonect [-f] -n “drive name”
Disconnect a drive. “id” is a drive item’s id. The id can be got by a command “drivelist”.
-d : Disconnect a connected drive by connected path. The value is a drive letter like a E or F on Windows. On macOS, the value is a connected path like a /Volumes/WebDAV or /Volumes/ftp
-i : Disconnect a connected drive by id
-n :Disconnect a connected drive by drive name
ex)
nd3cmd disconnect -d E
nd3cmd disconnect -d /Volumes/SFTP
nd3cmd disconnect -i 1432 -u email@host.com -p password
refreshpath
nd3cmd refreshpath path
Refresh a folder list in a connected drive.
ex)
nd3cmd refresh “E:\myfolder\pics”
nd3cmd refresh “/Volumes/WebDAV/myfolder/pics”
