On Windows 10 I have checked the “Mount on Boot” option but cannot connect to my mounted drives until I login. Does this feature work?
“Mount on boot” option works well.
We need to understand how to work “Mount on boot”.
- ndagent.exe log in.
- get a list of drives.
- mount the drive which set “Mount on boot”.
The drive item will be mounted because ndagent.exe is a service program.
I think your pc’s performance is great, so booting and logging in quickly finished before the drive is mounted.
Thank you for your reply, I will be a little more patient.
Jyyoon.
Confirmed, the mapping is working fine in boot mode.
Thank you for your prompt reply.
Regards,
Paul
You’re welcome.
Don’t hesitate to contact us.
