Minimize at start up
I’ve tried searching, but have not found the answer, so please forgive if this is an obvious item I just may have missed.
I have NetDrive set to connect to a NextCloud system, DropBox and OneDrive at login and all works well on my MacBook Pro. The only issue is the NetDrive app screen shows up and I have to minimize it. Is there a way to do this automatically or is that just the way the app works? I just need it to connect and then minimize to my task bar.
