Can I use Netdrive to migrate data from Dropbox to Google drive?
If I map both and just copy from one to the other will this work?
does it need to download all the data to my computer first or is it a direct copy.
Dear russ1,
Yes, you can migrate data using NetDrive.
If you copy and paste the data from the mounted DropBox to Google Drive, it is downloaded to your local computer’s cache folder and uploaded to the mounted Google Drive.
