MacOS 26 Tahoe - I can browse drive but they will not connect
I upgraded my M3 Macbook Pro to macos 26 (Tahoe). Netdrive will browse drives but not connect. I tried both the lastest version 3.18.825 and the prior version 3.17.730 and both exhibit the same behavior.
The logs show the mounts failing. Any suggestions would be helpful.
mine does not even connect
I think agent is not working. All connections are failing. can you help?
Dear Valued Customers,
We are currently investigating the connection issue with NetDrive on macOS 26 (Tahoe).
Several users have reported similar symptoms, and our development team is working to identify the cause and prepare a fix as quickly as possible.
We are doing our best to resolve this issue promptly, and we will update you as soon as a workaround or fix is available.
We sincerely apologize for the inconvenience and appreciate your patience.
