Is it possible to keep the entire contents of my personal laptop permanently synced with my Google Drive account (for offsite backup purposes) using CloudSync? And pros and/or cons of doing this?
It’s possible to keep sync between your Google Drive account and your local disk. With CloudSync you can start sync when you want.
But as you know Google already provides backup and sync tool and with it you can sync your Google Drive to your local laptop.
CloudSync is good for sync between Cloud storages. If your cloud storage provider has official sync tool I think it’s better to use their tool.
