Hello, I would like to ask why the netdrive3 is only available in English after downloading it. Why does this happen? I need simplified Chinese. Ask for help. Jeyun! ! !
Dear 765483006,
What version are you using?
The nit version used by my old computer is 3.5.434. Isn’t that 3.5.434 can’t support Chinese? If I want to use Simplified Chinese in version 3.5, how should I set it?
Sorry about that.
Localization was added from NetDrive 3.8.
There is no way in version 3.5.
May I ask if there is no way at all?
Dear 765483006,
Please update NetDrive version to 3.8 or higher.
Unfortunately, It can’t be helped.
Okay thank you
Don’t hesitate to contact us if you have a question.
