Issues using remote path with Azure Blob Storage
When I try to use the remote path option with Azure Blob Storage I cannot create new folders in the mount. I also experienced some issues saving files from InDesign that I think might be related. Here’s a screencast of the issue and my logs:
logs.zip (240.0 KB)
The issue has been resolved in the latest version of NetDrive. We recommend that you update your software to ensure the problem is fixed.
