Is it possible to exclude a folder from Sync?
Hi, I’m just starting with NetDrive3 and added a OneDrive account. Is it possible to exclude a specific folder from sync (like with the original Microsoft OneDrive app)?
I have one folder for backup which is big, and I don’t want, that it synced to my local HDD to save space.
Thank you!
NetDrive is not a sync program. Don’t worry about the big size folder.
It is requested on demand by a application you use like as a explorer or a text editor.
Thank you for your answer.
I understand it now better. Just to be clear:
So to access the files I always need to have an online connection?
Yes. You are right.
