I installed Mac OS Tahoe 26 and Netdrive doess not connect
I installed Mac OS Tahoe 26 and Netdrive doess not connect. Nothing works (Google, Dropbox, etc.). It tries to connect and goes gray.
Same things happen to me. After update to MacOS Tahoe, Netdrive no longer can cannot to all of my NAS drive. Any update to solve this problem?
Seem to have not gotten their attention yet.
Dear Valued Customers,
We are currently investigating the connection issue with NetDrive on macOS 26 (Tahoe).
Several users have reported similar symptoms, and our development team is working to identify the cause and prepare a fix as quickly as possible.
We are doing our best to resolve this issue promptly, and we will update you as soon as a workaround or fix is available.
We sincerely apologize for the inconvenience and appreciate your patience.
Looking for an update.
any update?
if nothing can be done, I would liek refund!
First of all, we sincerely apologize for the delay in providing you with a solution and for the inconvenience this has caused.
We have confirmed that NetDrive does not currently work properly on macOS 26 (Tahoe). The issue is related to the core module (ndfuse) that handles drive mounting. It was originally designed to support up to macOS 10.15 (Catalina). Starting from macOS 11 (Big Sur), Apple began deprecating traditional kernel extensions (KEXTs) and moving toward System Extensions and the new DriverKit architecture.
On macOS Tahoe, this policy is even stricter, which prevents the existing module from loading and causes the mount failure.
Our development team is actively working on adapting NetDrive to the new macOS architecture, and we are committed to finding a solution as soon as possible. While it may take some additional time, please be assured that we are doing our best to make NetDrive fully compatible with Tahoe.
We truly appreciate your patience and understanding, and we apologize once again for the inconvenience.
We have identified the issue where NetDrive could not mount drives on macOS 26 (Tahoe) and have prepared a test build that includes a fix.
You can download the test version from the link below:
Download NetDrive 3.18.835 (macOS)
Please install this version and let us know if it resolves the problem on your system. Your feedback will be very valuable for finalizing the official release.
We sincerely apologize for the inconvenience and greatly appreciate your help in testing this build.
3.18.835 is not stable, when will there be an update to Netdrive that will be stable?
