My server has some problems to run command “df -h”. When running this command, it will get stuck. I use ND2 to mount my server as network driver, and I think the “df -h” is run when mounting, caused program get stuck. Why “df -h” will be run? How to disable it?
What kind of server do you connect? WebDAV?
