I successfully installed netdrive on linux (I saw a green netdrive logo appearing). However, I can’t find a way to run netdrive or config it. How and what command should I run to config and mount google drive on linux?
You can run NetDrive by executing NetDrive.AppImage file.
Please be noted that current NetDrive for Linux version supports only Ubuntu 16.04.
Is it gui only?
Yes, GUI only.
