Hi so in PC A, i have several drives (about 20 drives) that saved in device (since i am a bit worries if its uploaded into server), is there anyway to move it into PC B?? i try to copy drives.dat , but seems no effect
And is it possible to add more than 24 drives in windows ?? maybe can mount into folder, like in linux ??
is there anyways to exports drives config, without need to use accounts as location ?? because
i dont want my config uploaded into server
i dont want unused drive to showed up, total i have about 100+ drives, if i only use 20 drives in one VPS, it would be messy if the other 80+ drives also showed up
Unfortunately, NetDrive currently does not support exporting drive item config. However, if you don’t want your drive item config to save on the server, there is a way to save them locally.
