I am using NetDrive 3 on my mac bookpro 2011 with High Sierra. Now I see the problem, that the graphic card is switched to the Nvidia card permanently because of the ndagent process.
What can I do, that the system is switching to the intel card? All because of a better battery time :-).
I noticed that because the gfx state tool (https://gfx.io/) does not swiched over to the Intel card. If I try to do this manulaly, then there comes a message: Because of ndagent…
Thanks for letting me know about gfx.io. First feedback from our engineers is that the switching may be caused by Qt library we are using. We will check it further and get back to you if we found something.
