When I connect NetDrive 3 to my google drive, it connects and mounts. however when I try to sync, or modify files on it from windows, it says i do not have permission? Any ideas?
Did you check ‘Read only drive’ on drive configuration? Or if you are using shared folder on google drive then please check your share permission.
yup, tried it all. I revert back to net drive 2.* and its working perfectly again with that. I will wait until the issue is fixed to upgrade.
