I have to disconnect and connect again my Onedrive drive from NetDrive3 because it stops showing anything on any folder. Windows Explorer always shows “Folder is empty” when I know there are files there.
Once I disconnect and connect again, I see all contents. Until it fails some minutes later.
I removed the Onedrive account from NetDrive3 and create a new account again. Seems something changed in the API from the previous configuration that I had because now it says “Onedrive (Graph API)” when before it was “Onedrive” only.
