We are considering using the following combined environments In that case,under our trial, we have encountered a case where the file lock is not working, is this a correct move?
a compound environment is an environment where the following two ways of doing cases are mixed
(1) Case1:When our people directly synchronize with the PC term by using the DROPBOX dedicated application.
(2) Case2:A case where our people are directly synchronizing with the PC using the NETDRIVE web app/IPHONE app.
Happy case NETDRIVE lock,DROPBOX file automatically lock. Viceverse.
I’m sorry, but I don’t understand what your problem is, can you explain it in more detail?
To use File Lock, you can either create and mount a Drive Item that connects to Dropbox, or you can access it from the File Browser.
If you mount from a Drive Item, you can select the file in Windows File Explorer and right-click to access the context menu for File Lock.
Title: Dropbox and NetDrive for Joint Use by MMB and JV
Our company, MMB, is using one Dropbox jointly with JV. Under this environment, we are considering limiting this distribution of NetDrive to MMB.
Access to Dropbox will be two app: a desktop sync application for Dropbox (distributed by Dropbox) and a desktop sync application for Dropbox(distributed by NetDrive).
JV and MMB are working together. Therefore, if MMB locks a specified file by NetDrive, we would like that file to also be locked when it is checked from JV through desktop sync application for Dropbox (distributed by Dropbox) .
Access to Dropbox will be two apps: a desktop sync application for Dropbox (distributed by Dropbox) and a desktop sync application for Dropbox(distributed by NetDrive).
NetDrive seems to be a good fit for the above requirements because it allows you to use Dropbox, which is cloud storage, as a local hard drive.
JV and MMB are working together. Therefore, if MMB locks a specified file by NetDrive, we would like that file to also be locked when it is checked from JV through desktop sync application for Dropbox (distributed by Dropbox).
NetDrive’s File Lock feature only works within NetDrive, so locking a file in NetDrive will not affect other programs. Please note that.
