File 0k on local drive mounted by SFTP not uploaded
Hi, if a 0k file is created on local disk mounted by netdrive, this file is not uploaded to the SFTP path.
Version 3.18.1111
Can it be solved?
Dear license-1d4d,
Thank you for reaching out.
In response to your inquiry, NetDrive does not support the upload of 0-byte files. This is by design, as many systems, including cloud services, often interpret 0-byte files differently or may not handle them effectively, leading to inconsistencies or errors.
0-byte files are commonly used as placeholder or temporary files and may not contain any usable data. Therefore, NetDrive omits these files from the upload process to ensure stability and compatibility with most storage environments.
Please feel free to reach out if you have further questions or need assistance with other aspects of NetDrive.
Best regards.
