NetDrive version: 3.6.571
Windows/Mac Version: Windows 10 Enterprise
I had to drop back to 3.6.548 on my work system because the latest beta will not complete initialization enough to even give access to the GUI to get diagnostic information to report more information with.
The only difference between this system and my other systems where the new Beta is working is that my OneDrive for Business that is associated with this login uses Multi-Factor authentication which may require that I go through the process of providing my credentials every 3 days (including the code from my M$ authenticator).
The only other difference would be the use of Cylance PROTECT as the AV but the Cylance logs do not show that anything was blocked and/or quarantined either during the install or the startup process after the reboot.nd3log.zip (8.0 MB)
