I got the message that an update was ready to be installed. I confirmed that I wanted to install this update, but got an error (see print screen below). The first error is in Norwegian and it says that the account already exist.
Do you have a suggestion how to solve this
Dag Erik Wiig
                    October 9, 2018,  9:09pm
                  2
              Hello Dag Erik Wiig
Could you attach log files to figure out what happened?
The log files are in “%TEMP%\Bdrive”.
Here are fresh log-files.
Dag Erik Wiig
------ Original Melding ------
NetDrive3_Setup.log  (84.8 KB)
NetDrive3_Install.log  (564 KB)
                    October 15, 2018,  6:32am
              I reviewed log files you attached.
I found the error but failed to figure out why the error occurred.
Could you try to uninstall NetDrive3 from Add/Remove Programs in control panel and install NetDrive 3.6.571 again?
I have re-installed Netdrive with the new version and it works fine. Thanks.
Dag Erik
