NetDrive version: 3
Windows/Mac Version: Windows
Lena has suggested I create topic.
Can’t connect, keeps showing error message ‘WebDAV: Network path already used’.
How do I fix this issue?
NetDrive version: 3
Hello ashleigh
The message you faced means there is a network drive path “DriveName-windows_account_name” already.
For example, “WebDAV-username”
If you can see the drive in explorer, disconnect it.
Or, you can set the drive item as a local drive
It will be solve your issue.
