Hello ,
I would like to know if it is possible to have several accounts (2 or 3) of Onedrive at the same time.
Data from one cloud should not merge with data of others clouds.
I would like to know also if there will not be the typical logging problems, where the program or the browser continuously losts the passwords .
Best regards ,
You can mount multiple OneDrive or OneDrive for Business with NetDrive 3.
Please refer to following topic.
For the second question, you can use auto-login option in login screen.
