Does ND3 support ssh-ed25519?
I think I have done everything correctly, but I cannot connect using a ssh-ed25519 key. I’ve had to generate a less secure ssh-rsa key and add it to my authorized_keys to connect to my newest servers. I had wanted to move everything to ssh-ed25519. Is this just not possible? Putty/kitty works fine.
Hello brian.
Is your new key file putty format or open-ssl format?
NetDrive supports only open-ssh format.
Hi jyyoon,
Good question. I should have clearly stated that.
Yes, both the working and non-working keys are in open ssh format.
The working ssh-rsa key begins with:
-----BEGIN RSA PRIVATE KEY-----
The nonworking ssh-ed5519 begins with:
-----BEGIN OPENSSH PRIVATE KEY-----
Hello @c5e3-netdrive @brian-2e86
You are right. Currently sftp connection of NetDrive3 does not support ed25519 as you know.
We will fix the issue in some days.
If the issue fixes, I will let you know to try it.
Could you try with the following url’s version?
http://files.bdrive.com/netdrive/builds/2332c1ef316743448faa415fbb9e285e/NetDrive3_Setup-3.7.686.exe
Sorry I was away. I will try it this afternoon.
