Hi
the drive keeps disconnecting whenever i access a specific folder. It’s a large folder (full of .raw photos) so as it’s loading it immediately disconnects and i can’t get to any of the files.
Help!
Greg
Hi
Help!
Greg
What cloud service do you connect?
None
It’s just a netdrive3
Yes I know that
There are lot of services that you can connect using NetDrive3. Where is your photos? Dropbox?
