Hi! Is there any way to connect to Backblaze using a normal application key instead of the Master Application Key?
Thanks!
Thanks!
Dear fernando-baraja,
Currently, NetDrive does not support direct access only to the specified bucket (normal application key).
We will discuss feature request about this issue.
The version below is the modified installation file to access the specified bucket using the normal application key.
https://files.bdrive.com/netdrive/builds/f21f940231094294937a30117ecf74ca/NetDrive3_Setup-3.17.741.exe
