I’m trying to switch from NetDrive2 to NetDrive3 to connect to a SFTP server, but I have to use a PEM/RSA PRIVATE KEY file for authentication. I cannot find an option for that in NetDrive3. How should I go about it?
When you make a SFTP connection you can specify your PEM file in following window. Click 'BROWSE" button to select your key file.
Yes, I’ve tried that but it didn’t work - it works in NetDrive2 and other software but not in NetDrive3
Ah, NetDrive support only OpenSSH PEM format. Please convert your RSA PEM format to OpenSSH PEM format before using.
