Hi There, I tested NetDrive3 with Wasabi and it works well. When I purchased I got the wrong one CloudSync. What is the difference between the two? Can I connect to Wasabi with CloudSync? Can I cancel order or switch over to NetDrive3.
Thanks,
Thanks,
NetDrive is mounting software where is CloudSync is for syncing between cloud services.
Do you want me to cancel current order for you?
Best regards.
If you can transfer to Netdrive3 that would be best. If not then cancel and I will order netdrivr3.
Thanks,
Khanh
