Cloudsync does not work, when pc is not logged in
i installed CloudSync a few days ago and it works very good. My problem is, that the syncjob is not working if the pc is not logged in. Is there any way, to run cloudsync as a service or start the syncjob as a task by windows taskplaner?
Regards,
Christoph
Hi @technik2,
CloudSync does not support unattended sync. Users must be logged in and the CloudSync app must be running for the sync to work.
Regards,
Steve
thank you very much. I this case, cloudsync is worthless for me. I am looking for a tool, which can sync files without user login.
Regards,
Christoph
