Today I got the NetDrive3 upgrade notice from my v3.11.204 to v3.12.231. After applying the upgrade and relaunch NetDrive3, I found the version still remained in old version. I also tried to download v3.12.231 installation exe file from website, still couldn’t success to upgrade. (Reboot after installation was tried without any help.)
Please let me know how to solve this problem, thank you.
Thank you for your reply. After uninstall (remove dir manually because normal uninstall procedure didn’t work, bdrive directory and data still existed), reboot and re-install, the new version was installed. I never encountered such kind of problem - every time version upgrade is smooth without problem. It’s so weird.
Can confirm when trying to install through the program update, it will go through the install and say its complete. But does not actually update the program.
