Can NetDrive work with DUO Unix / pam_duo?
A client added Duo Unix - Two-Factor Authentication for SSH with PAM Support (pam_duo) to their servers
NetDrive2 and 3 now both fail to connect. Is there anything that can be done to still support these servers?
Thank you for using NetDRive.
Unfortunately, it’s not supported at present.
I move this topic to Feature Request category.
Thank you! It’s a great feature. I just click approve on my phone after I connect via SSH. However NetDrive sees it as an instant failure rather than waiting for the login to succeed. The fix may be as simple as adding a time out variable to wait for the server to finish its login process…
