Can I connect to a Synology C2 object storage?
I can not find a s3 “compatble” settings, only s3 .
Thanks, Willy
You can access C2 Object Storage using S3 drive type.
Add S3 and press CONNECT. Configuration screen will be shown.
Use your bucket’s Endpoint as Server Address.
Create a access ID and secret key on C2 Object Storage home page and use the key as Access ID and Secret Key.
