Cache limit is no being honored
NetDrive version: 3.4.369
Windows or Mac: Windows
Windows/Mac Version: Windows 10 Enterprise 2016 LTSB
I did not change the cache size since install and it’s not being honored.
I tried creating a huge file on a remote mounted drive by compressing a lot of files using 7zip into a single file and it all just happened in the cache exceeding the cache limit by far.
You should refer this article to understand how NetDrive cache works.
Thanks!
