after disable Background uploading from the config and reboot the computer.
I don’t see any difference.
The file is uploaded after the “Windows copy”
Is it normal?
what should do Background uploading??
Is it normal?
If you want to upload your file while windows copy. Please enable ‘on-the-fly’ option on drive setting.
