Hi, I’m “trying before buying” Netdrive3. When I try to mount a Backblaze storage using the “Master” key, it works correctly, but when I use an “Application” key, it does not work (I get “400” errors on the log).
Is there a way to use an “application” key instead of the “master” key?
