I see that this is a common problem for NetDrive, for which the solution seems to be to rollback to a previous software version, but I have a CloudSync service and I don’t know how to address this. Will the same solution apply or is there another way? What version do I install if that’s the case? Thanks!
Dear chrisverm96,
Thank you for using CloudSync.
Have you tried OneDrive for Business (Graph API) when choosing a protocol type?
If you do not see the OneDrive for Business (Graph API) protocol type on add task page, please update your CloudSync to the latest version.
This worked! Thank you!
