All uploads are corrupted
Out of nowhere my Netdrive3 startet to corrupt all uploads (version 3.18.1164). Initially i thought the problem was caused by my Synology NAS. However, when i tried to create a drive to my Google Drive and the uploads were still corrupted I realized that the problem was Netdrive3 itself. I rolled back to version 3.18.1111 and now uploads works again. Any one here with the same problem?
This is the NetDrive Support Team.
Thank you for reporting this issue.
We have confirmed that the same file corruption issue occurs when testing uploads to Google Drive, as you described.
At this point, the issue appears to be related to NetDrive version 3.18.1164, and our team is actively investigating the root cause.
We are working to fix this issue as quickly as possible, and we will keep you informed once a corrected version is available.
In the meantime, as you have already discovered, we recommend using the previous stable version (3.18.1111) as a temporary workaround.
We sincerely apologize for the inconvenience and appreciate your patience.
We have released a new version that includes a fix for the file corruption issue during uploads you reported earlier.
Please download and test NetDrive version 3.18.1166 using the link below in the same environment.
:link: Download link:
https://downloads.bdrive.com/netdrive/builds/aebc604e3f0d43c58e47f57366ac3e99/NetDrive3_Setup-3.18.1166.exe
This version includes fixes related to upload data handling.
After testing, please let us know the result so we can confirm whether the issue has been fully resolved.
Thank you for your cooperation, and we apologize again for the inconvenience.
I can confirm that the issue is fixed in version 3.18.1166 :grinning_face:
Many thanks for your very quick response.
Best Regards,
Morten
Thank you very much for confirming that the issue is resolved in NetDrive version 3.18.1166.
We really appreciate you testing it so quickly and letting us know the result.
If you have any further questions or encounter any other issues, please feel free to contact us anytime.
