After mapping FTP, the display is garbled. My FTP uses simplified Chinese,Windows 10
Could you change character set in options after pressing “OPTIONS” in a configuration of the drive item?
Dear support:
Thanks for your reply!
I find the OPTIONS and change to the Force UFT-8.Then My problem is solved.
Thanks.
It’s a good news!
Don’t hesitate to contact us.
