r91085
1
Is it possible to caching the read/write file until the cache size is full then remote the oldest cached file for new file ?
tsjeong
2
Dear r91085,
NetDrive removes caches after some time when the file is not used by any process.
Please refer to the following topic.
r91085
3
So even if I still have enough space, there is no settings for me to keep the cache longer for later usage? Is it right ?
tsjeong
Dear r91085,
You can change the cache settings by changing ndfs.ini.
I wish the following topic will be helpful for you.
https://support.bdrive.com/t/cache-not-working-with-s3-buckets/222493/6
