Will Not Stay Registered
#1
I am trying to move my Netdrive2 install from my old laptop to my new one. I have removed Netdrive2 from my old laptop completely. I have installed Netdrive2 on my new laptop and can successfully enter the registration information. However, even though it says it was successfully registered if I reboot my computer it goes right back into trial mode. Why will it not stay registered?
#2
Dear caronson.
I think the license info file was recovered by some program when your computer is rebooted or failed to save the license file when you register.
If you register your NetDrive2 license on https://accounts.bdrive.com/plans_products/NetDrive2/, you can download the license file from the site and import it from NetDrive2 application.
#3
Problem appears to be resolved. Thank you for the suggestion.
closed #4
