I have the following problem with the Netdrive 3 installation:
When I transfer a file (some 30…40 MB) from a local drive to the remote (WebDAV) server, it seems that the transfer is not finalized, the file does remain in the cache. How can I ensure that the file is completely transferred to the external server?
I assume that this does happen especially with a slow internet connection.
Thank you for your feedback. The “on the fly” option could be a solution. Does it work with the Explorer only, or does it work as well if the file transfer is performed by a powershell script?
Is there an option to open the upload page by a script (PowerShell) to see the progress automatically?
Best regards, Rudolf
