I have two copies and one I mount as D on one computer on the other computer I mount as E. It keeps trying to force them to use the same. This is not possible. Please advise on how to allow it to be different drives on the two systems. Thanks.
Thank you for using NetDrive
Unfortunately, the feature you want is not supported. It is a feature of NetDrive3.
