Folder and filename with umlaut get corrupted, that means the programm is not useable.
Is there a solution?
Hi Roland,
configure a site, use the Advancrd button und select Encoding UTF-8.
Bei mir hat es dazu geführt, dass ich per WEBDAV alle deutschen Sonderzeichen anzeigt bekomme.
Regards,
Mega Byte
thanks for your hint.
What I found out:
In NetDrive3 there’s a button “config”, then “options” which is only accessible when the drive is disconnected.
One option is: “attempt … to UTF-8”, which is “ON” by default. Switching it to “OFF” was the solution.
As I understand, it should be the contrary?
regards,
Roli
