For some reason, with the latest update of NetDrive, now every explorer folder icon in my task bar has the NetDrive logo instead of the default windows folder icon. Even if it is NOT a connected NetDrive folder.
Is there a way to stop this?
Could you check it after rebooting the pc?
The same thing is happening to me, even after rebooting (twice) and even after quitting NetDrive from the notification area. Even the popup window when I print to PDF has the NetDrive icon (and a few things I tried to print had .log extensions instead of .pdf, which never happened before the NetDrive update). Please fix this ASAP.
I reproduced this issue, I will fix this ASAP.
