Your ever so nearly their, with orbit you can have two types of user credentials.
The account login username/password
Orbit API Key
When using type one NetDrive now connects however when using type two it still fails.
I suspect this is because API keys aren’t allow to list the containers. Instead of failing when it gets a 403 error could you allow the container name to be entered?
With an API key login you can use a number of containers you just can’t list them, see screenshot from SwiftStack for example.
Full allows you to create/edit servers change firewall rules etc which clearly isn’t a good idea. Orbit Storage Only only has access to Orbit and allows us to control what containers that key has access to.
I am seeing some issues when I delete a file I get the error bellow, sometimes the file will come straight back other times I need to disconnect and connect again and the file will return.
Only seems to happen if I have turned on Always retrieve file list from server, so I assume I shouldn’t turn that on?
The operation can’t be completed because one or more required items can’t be found.
(Error code -43)
