Just downloaded netdrive 3 for mac, running MacOS 10.15.3. I attempted to setup a WebDAV connection and the program froze while attempting to connect. Force shut down, rebooted program, and it is now stuck on splash page saying initializing SDK. Any assistance greatly appreciated.
Could you check nd3svc and ndagent are running or not?
Please input a following command in terminal.
ps -A | grep nd3svc
ps -A | grep ndagent
If nd3svc and ndagent are running, check the hosts file to see how the ip of localhost is set.
If a connection to localhost is failed, NetDrive will not work.
I restarted the services and program is now loading normally. Thank you for the assistance.
That’s a good news.
If you have a question, don’t hesitate to contact us.
