I have a connection that worked for a while without issues but as of the last 3 versions it still authenticates OK but I get 403 Errors and I can’t see anything in the drive.
This is connected to min.io and it’s setup as an S3 connection in NetDrive.
I saw mention of an S3 Compatible option like for Wasabi but I don’t see that as an option in my list.
Thanks a ton for your help, I just purchased another perpetual license and am looking to buy a couple more. I’d rather stick with NetDrive rather than going with another program that does work but I would have to license as well.
Here is a snip of the error messages:
[2021/01/09 12:42:53.286] [ERROR ] [ 18008] [PROTOCOL ] S3::GetBucketRegion >> HTTP 403
[2021/01/09 12:42:53.286] [ERROR ] [ 18008] [PROTOCOL ] S3::Connect Location not found: bucket videos-podcasts
[2021/01/09 12:42:53.473] [ERROR ] [ 18008] [PROTOCOL ] S3::GetBucketRegion >> HTTP 403
[2021/01/09 12:42:53.473] [ERROR ] [ 18008] [PROTOCOL ] S3::Connect Location not found: bucket vtt
[2021/01/09 12:42:55.388] [ERROR ] [ 13468] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:55.388] [ERROR ] [ 16704] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:55.957] [ERROR ] [ 13476] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:55.958] [ERROR ] [ 13472] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:56.278] [ERROR ] [ 13468] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:56.279] [ERROR ] [ 16704] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:57.663] [ERROR ] [ 13476] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:57.664] [ERROR ] [ 13472] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:58.391] [ERROR ] [ 13468] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/09 12:42:58.392] [ERROR ] [ 16704] [FILESYSTEM] [O:bdservicehost.exe] FileSystem::OpenDir => AERROR::FAILED :
[2021/01/13 22:00:54.203] [ERROR ] [ 16704] [PROTOCOL ] S3::CreateDirectoryW >> HTTP 403
[2021/01/13 22:00:54.203] [ERROR ] [ 16704] [FILESYSTEM] [O:SearchIndexer.exe] FileSystem::MakeDir => AERROR::FAILED : \System Volume Information
[2021/01/13 22:00:54.422] [ERROR ] [ 13468] [PROTOCOL ] S3::CreateDirectoryW >> HTTP 403
[2021/01/13 22:00:54.422] [ERROR ] [ 13468] [FILESYSTEM] [O:SearchIndexer.exe] FileSystem::MakeDir => AERROR::FAILED : \System Volume Information
[2021/01/13 22:01:06.388] [ERROR ] [ 13468] [PROTOCOL ] S3::CreateDirectoryW >> HTTP 403
[2021/01/13 22:01:06.388] [ERROR ] [ 13468] [FILESYSTEM] [O:SearchIndexer.exe] FileSystem::MakeDir => AERROR::FAILED : \System Volume Information
[2021/01/13 22:01:06.599] [ERROR ] [ 13472] [PROTOCOL ] S3::CreateDirectoryW >> HTTP 403
[2021/01/13 22:01:06.600] [ERROR ] [ 13472] [FILESYSTEM] [O:SearchIndexer.exe] FileSystem::MakeDir => AERROR::FAILED : \System Volume Information
[2021/01/13 22:09:44.492] [ERROR ] [ 13476] [PROTOCOL ] S3::GetFileList_ObjectList >> SSL peer certificate or SSH remote key was not OK(60)
[2021/01/13 22:09:53.428] [ERROR ] [ 13472] [PROTOCOL ] S3::GetFileList_ObjectList >> SSL peer certificate or SSH remote key was not OK(60)
