msbu
June 7, 2021, 3:52pm
1
Hello!
I have problem with my files when connect to Synology
some of them don’t show (simple excel file for examle)
some folders open very long or never
In Windows 10 through the same soft i have no problem
I have last version V3.15.415
Please help, thank you!
June 9, 2021, 12:48am
2
June 10, 2021, 9:23pm
I was reviewed the files you attached.
But it was difficult to figure out.
Please let me know the filename which is not shown and the folder name which is too slow to list files.
msbu
June 11, 2021, 11:49am
5
Don’t show:
Files/Клиенты архив/1 В работе/Александр-Сады Майндорф/Сады Майндорфа.xlsx
Files/Клиенты архив/1 В работе/Сергей Грива - Топаз/Счет Сергей Михайлович.xlsx
Slow to list (through the “browse” button in the main menu - it was once, working normal now):
June 15, 2021, 12:53am
6
Thank you for feedback.
I reviewed the log files again.
I think the name of the files which were not shown could be not a UTF-8 encoded file name.
If you change the file name to UTF-8 encoded, you can see the files in the finder.
msbu
June 15, 2021, 2:40pm
7
Hello!
Thanks.
How can i change the files name to UTF-8 ?
On Windows 10 i haven’t got any problems with this files…
June 15, 2021, 9:50pm
9
There are so many ways to change filename character set to UTF-8.
Windows system uses multibytes character set by default. Otherwise Mac uses UTF-8 by default.
If you connect DSM in a browser on a Mac , you can change a utf-8 filename with File Station.
msbu
June 18, 2021, 9:38pm
10
Thanks!
Yes, after change the name in DSM File Station - i can see the file in Net Drive
But i have a question:
I use “Yummy FTP Pro” before Net Drive and this issue didn’t appear
Why NetDrive have on Mac have this problem with only few .xlsx files
All files are identical, created on Windows (use multibytes character) but only with some of them NetDrive have problem…
June 20, 2021, 8:29pm
11
It’s a Finder feature rather than a NetDrive issue.
June 27, 2021, 8:29pm
12
