How to use NetDrive on macOS Big Sur and later
  1. When the CONNECT button is pressed in NetDrive, you will see “System Extension Blocked” message. Then press “Open Security Preferences” button.
    Screen Shot 2020-07-07 at 6.42.38 AM
  2. Press the lock image to make changes, then press “Allow” button.
  3. If “Bdrive Inc.” is unchecked, then check it. If “Bdrive Inc.” is checked, uncheck and then check it again.
  4. Restart your macOS.
